Error code-19 Blue Screen Error
My desktop keeps getting a blue screen error message that reads:
***STOP: 0x0000007E (0x00000005, 0x805E492E, 0xF89303BC, 0xF89300B8)
Could you please help me fix it.
Thanks
Thanks
Your computer broke down. To fix the problem, you need to format your hard drive, reinstall your Windows operating system and then restore the date from the most recent back up, if you have a back up.
Hi Shaheryar,
The error you're facing is as a result of video card error or graphics card error or the operating system has crashed. I've also faced a similar problem. This is how I was able to solve the problem.
I tried booting the hard drives one at a time. You will also need to disconnect everything possible to be disconnected beginning, with the video card, sound card, CPU fan, until you are able to boot and the screen can display. All these operations you need to do, when your computer is switched off and disconnected from the power plug, so that you can plug in and retry.
You may also go to Microsoft.com and look for a hotfix software. In another manual install method, you may need to disable Kernel Authentication mode, using the IIS manager.
These commands will stop the HTTP service. The steps given should be able to solve your problem.
Thanks
Blue Screen Error is commonly known by IT Pro's as "Blue Screen of Death Error" (BSoD) and "Stop Error." This happens when the operating system, a system error which is detracting. Stop error occurs mostly because of Driver and Hardware problems.
***STOP: 0x0000007E (0x00000005, 0x805E492E, 0xF89303BC, )xF89300B8)
Above error 0x0000007E, is commonly caused by the following:
The first thing to do is, check if your computer still has enough disk space. You need to delete unimportant files and unused programs, to save disk space by using Safe Mode that permits you to solve Windows problem. I suggest to visit link below to scan your computer.
