Error Code 19 on Saving The Sims Medieval
I can’t save my “The Sims Medieval” game.
I always get a Code 19 error.
How can I resolve it?
An unexpected error has occurred while saving: Error Code 19.
Please consult the readme for details.
The error that you are getting is maybe caused by overcrowding in a lot. Try editing the town and then move some to other places or return them to their proper places if you moved them from their original location. If this does not fix the problem, try doing a Save As instead of selecting the normal Save option.
This will decrease your chance of getting a corrupted file. You may also try traveling overseas and then do your saving there. Every time you make a normal save using the Save option, the game automatically creates a backup of your previous saved game.
If you still can not make a save, locate first your saved game in the installation folder and then make a backup copy. It is usually located in The SimsUserData directory, but I’m not sure if The Sims Medieval also uses these sets of directories because this is from The Sims 1.
Just try to locate your saved game, make a backup copy then uninstall The Sims Medieval and then install it back and then copy your saved game on the right folder where you originally copied it.
