Error code 25 with Nvidia Graphic Card! Thanks
Hello, I am passing through a problem with my Nvidia Graphic Card which is often showing me the message Error code 25. I didn’t find any post on this in the forums, so couldn’t do anything. Can you provide some useful tips for me to solve this? Thanks.
Answered By 590495 points N/A #154212
If the error code pops up on your screen most of the time, try restarting your computer then see if it appears again. If it did appear again, try doing a clean installation of the video card’s driver just to restore it to its default configuration and possibly fix any corrupted files that may have developed in the system in the long run. Uninstall the driver of your video card through the Add or Remove Programs applet. Click Start then Control Panel.
Click Add or Remove Programs. Find and select your graphics card’s software then click Remove. Wait for it to finish then restart your computer. After booting, check your computer for any possible errors. Use a disk utility application to check the system. Run again the installer for your graphics card then see if this fixes the problem.
You may also try upgrading your video card’s driver. To download the latest version of the driver for your video card,
You may visit NVIDIA.
