SteveRubel
Posted on - 09/26/2011
I work in messenger many hours per day but in previous days I have many errors on it and I do not know why these errors happened all errors are in numbers like 80004005. How to solve this error so it does not happen again? Â
We can't sign you in to Windows Live MessengerÂ
Signing in to Windows Live Messenger failed because the service is temporarily
unavailable. Please try again later.
Click Troubleshoot to try and fix this problem.Â
Get more information…
Error code: 800004005.
Error code 80004005: Unable to sign in to Windows Live Messenger
To solve your problem you have to follow these easy steps:
1) First of all check that what version of messenger is installed on your machine & if it is an older version than you need to upgrade it to the newer version this may fix this problem.
2) If the problem still don’t fix than you have to clean your cache memory for the messenger to do so you have to follow these steps:
i) If you have windows xp or 2000 than click on start menu from this choose the run menu than type cmd command & than click on OK a command window will appear.
ii) If you have installed windows 98 or ME than click on start button, click button, here you have to type command & than click on OK.
iii) Now on the command prompt window you have to type the following commands after every command line & than press enter.
cd
cd %appdata%microsoftÂ
cd "msn messenger"Â
del /s listcache.dat3)Â
3) You simply try to log in your windows live messenger again.
