Hi.
I bought Windows 7 CD and trying to upgrade from Vista x64-bit Ultimate Edition but after 15 % installation, it gives an error code 80070570.
I don't know what this error is about but every time I try to upgrade, I face the similar problem. Its frustrating me. Can someone give me direction as to what the possible problem could be.
Error code 80070570 when trying to install Windows 7
I understand it's quite frustrating when things are not going right. I'll give you a medicine to cure this problem.
Error 8007057 is caused by incompatibility with your Random Access Memory. Things to do;
Insert Windows 7 upgraded DVD in the CD ROM;
Reboot computer, boot off DVD;
A step by step will guide you on the installation;
Once Windows has been set-up, run Windows Update and download any available updates.
Reboot computer and restart it back;
Activate your Windows in the utility, type product key and then activate your Windows.
These steps should let you install your Windows.
Hi Norman,
Lets try the following steps:
Copy the windows 7 DVD contents to the hard drive. If able to copy successfully it means that windows 7 files are good and able to read and no file corruption. If unable to copy DVD media is corrupt.
Run the upgrade setup from inside the Windows Vista by clicking on the file Setup.exe.
Another option is you can boot from the Windows 7 DVD and start the upgrade.
Possible cause of file unable to process the file to due read problem.
Hope this works out for you.
Vistashen
