Error code “80072efe” while trying to update Windows
Hello guys.
I found the following error code "80072efe" while trying to update Windows.
Virus and spyware scans run without a cure, while firewall is disabled and failed to update.
If anyone experienced this problem then please share how you overcame it.
Any suggestions from experts will be really appreciated.
Thanks in advance.
Answered By 25 points N/A #96147
I have found a solution for the problem that you are having right now you need to download and run a program and I will guide you to the procedures that you will need to do.
Please download this program
After downloading it you need to run the program and please read and follow the steps carefully that is given by the program. Restart your computer and update your antivirus and check for updates on your computer.
And also please install a registry fixer and cleaner it might have been a virus has messed up with your registry entries.
