Error code C00D11B1 while playing an MP3 file
Hello, I was trying to play an mp3 file in my windows media player while an error occurred says that the file cannot be played with a code error code C00D11B1. I checked my sound device for the solution but the same message showed. Any ideas how to solve this? Thanks.
Best Answer by Santiago Skyo
Answered By 0 points N/A #136654
Run a Disk Cleanup to repair or replace some damaged file. Do this by clicking on Start> All Programs> Accessories> System Tool and then click the Disk Cleanup. And also, you can also run the System File Checker. Just open your Command Prompt and then type sfc /scannow and press enter.
Another workaround that may fix this problem, run the Windows Update or you can also go to your device manufacturer's webpage and check for an updated driver. Check if you are running an MP3 file that has compressed ID3 headers. Create a copy of this file and you can use a ID3 editing program that is not from Microsoft to remove the ID3 headers. ID3 headers is where you store the song's album information.
Answered By 0 points N/A #136655
Hai there,
Your sound device is not functioning properly. Try using Device Manager to check the status of your sound device.
  To check the status of your sound device
Do one of the following:
## If you are running Windows XP, click Start, right-click My Computer, and then click Manage.
## If you are running Windows Vista, click Start, right-click Computer, and then click Manage.
##In the pane on the left, click Device Manager.
##In the pane on the right, expand Sound, video and game controllers, and then look for the name of your sound device.
##Do one of the following:
##If your sound device is listed but the icon includes a red "X," the device has been disabled. To enable the device, right-click the icon, and then click Enable.
##If your sound device is not listed, in the pane on the right, expand Other devices. If Multimedia Audio Controller appears in the list, right-click the icon, and then click Update Driver or Update Driver Software. Follow the on-screen instructions to find and install the driver software.
##If you are not able to find and install the correct driver software, see your computer manufacturer's or sound device manufacturer's Web site for further assistance.
##You do not have a sound device installed on your computer. Install a sound device, and then try to play the file again. For details, see your computer manufacturer's or sound device manufacturer's Web site.
##You are trying to play a file on the Internet and the server might be temporarily unavailable or there might be a network issue. Try again later.
##You are trying to play an MP3 file that contains compressed ID3 headers. The ID3 header is a portion of the file that stores the song's album information (for example, the song name, artist name, album name, and genre). This information is sometimes called a "tag."
##To fix the problem, make a copy of the file and then use a non-Microsoft ID3 tag editing program to remove or reset the file's ID3 headers. After you remove the ID3 headers, Windows Media Player should be able to play the MP3 file.
Attempting to remove ID3 headers might damage the file and make it unplayable. Therefore, always make a copy of the file before you edit it.
If this solution does not resolve the problem, the file might be corrupted.
Hope these helped.
Have a nice day.
