I am running Windows 7 Ultimate x86, with a Virtual Box version 4.0.0r69151. Every time I try to install the OS/2 in Vbox, there are codes that I get like these:
The system detected an internal processing error at location ##0160:fff5fbd5 – 000d: 9bd5.
The system is stopped. Record the location number of the error and contact your service reprehensive
TRAP 000e ERRCD=0000 ERACC=**** ERLIM=********
Internal revision 6.514, 93/04/12
How could I install the OS/2 in Vbox properly without getting these errors?
Error Codes appearing while installing OS/2 in Vbox
What I think to be the possible cause for the errors that you have displayed is the virtual box version that you are trying to install on your computer. Taking into consideration that your computer is running on a windows x86 operating system, you will need to make sure that the Virtual Box application that you are installing is a x86 version too because otherwise it will not work. Therefore go to the internet and search for a x86 version of the virtual box, download it and use it for the installation. You will also need to ensure that the site you are downloading from offers trusted software which are not corrupt but in good working condition.
-Richard Gabriel
