Jeshan
600 points
Posted on - 06/17/2012
Hey!
I was using my IE10, and I keep receiving this message from Google to update my browser. I tried modifying the user-agent string to Google Chrome, and it worked. But, I’m not comfortable with my solution.
 Is there anyone who has an alternative fix for this?
Here’s a screencap of the notification.
Your browser configuration is not supported. Learn more Update to a modern browser
Waiting for the response
Thank You
Error Configuration Not Supported IE10 and I keep receiving this message
The problem may be with your browser settings.
1.      It may be that the software is emulated to an earlier version. You need to restore this.
2.      Delete all the browser history files, temporary files and cookies before running it again.
3.      Reinstall the IE10 and then try once more.
4.      The firewall and the antivirus web protection scheme has to be checked for any such problems that is restricting certain works for the site into your machine.
5.      The detailed specification for the problem and the system is required. The mechanism requires extensive debugging approach to the application part of the user.
6.      If none does, post a blog at Microsoft.com.
