Error: Configure Remote Support Software Manager
I am trying to setup Remote Support Software Manager but I am getting issues related to my country or location. Did anyone have the same problem? Is there a fix for this? Is there a separate download for just the application only, instead of downloading several applications included in the package?
Thanks in advance for your usual help.
ERROR: Your Country/region is not set. You must configure. Remote Support Software Manager before you can use the
product. Please perform configuration using the RSSWWM configuration shortcut (typically "All Programs – Hewlett Packard
Remote Support Software Manager – Configure Remote Support Software Manager").Exiting the program now
