Jared T
Posted on - 11/12/2011
Hi Experts,
I was configuring Norton Ghost 14 when I got this error message, see below. I was already using the administrator privileges but I still got the error message. I got full control and rights as administrator but still I can’t configure Ghost properly.Â
Any advice on what to do next? Please help.Â
Thanks in advance.
Norton Ghost
Error E1AD3212: You do not have sufficient privileges to perform this operation.
See help for more information about security settings.
Error configuring Norton Ghost 14 – Error E1AD3212
Hello Jared,
I hope you're doing fine. I suggest you to follow the instructions below to solve your problem. Take note that it may lead to data expose or lost into threats online. Make back up into all your files. Make sure that your computer firewall is on.
Go to add/remove programs and uninstall back up exec system recovery
Make sure that your drivers and firmware are updated
Disconnect temporarily non internal attached files
Uninstall filter drives temporarily or perform maintenance task to remaining drives
Use msconfig.exe windows to start up selectively maintaining system
Reinstall back up exec system recovery and reboot your computer
Complete the installation
I hope it helps.
Zorian
First you must do is try to download the error repair tools and then after you download you just simply try to install that to your computer and then try click the scan to start scanning your computer or software and then after scanning your software just simply repair the found errors to your software then simply uninstall the application to your machine then try to reinstall it again into your machine then after just simply restart your computer if it’s possible then try check if there an corrupted file to your application just simply try on that. Â
Ben
