Stephan H
Posted on - 08/23/2011
I am using Dial up Bluetooth connection to connect to Internet, yesterday I have installed pirated software downloaded from Internet and today when I try to connect to Internet, I am having trouble in Bluetooth dial up connection.
I got following error message while connecting.
Error Connecting to Bluetooth Connection
Opening port…
Error 633: The modem (or other connecting device) is already in use or is not configured properly.
If you continue to receive error messages. You can enable logging for analysis.
Enable logging
For logging options, see diagnostics
Logging options can also be accessed by clicking the Remote Access Preferences menu item under the Advanced menu of the Network Connection Folder.
I am using Internet on my brothers PC to share my problem, can anyone help me regarding this problem?
Error connecting Bluetooth dialup connection
Hi Stephan,
This type of connection is a portable connection and it is not a permanent connection so this type of error comes frequently in the computers but no worries there is a solution for it.
First of all this error message shows that the device is not configures properly it means may be there is an error in the IP address or other settings. You might forgot to saved those settings which you have done while using first time. So check it again.
Other thing which this error message shows is that there is a problem of already usage of that device. It simply means that this device has assigned a particular IP and now the other one is not assigned to this. You may delete the first one then enter again new one to connect from net from this PC.
You can also check on the box of enable logging and then try it may be it runs by asking some of minor questions from you.
The solution posted, sounds really good, however, some steps on how to accomplish the solution would be very helpful
