Error in connecting to Domain on Windows Server 2008
Hi all,
I am receiving that error message when I'm trying to connect this computer to my Domain that is on my Windows Server 2008 machine. Below is the full error:
Note: This information is intended for a network administrator. If you are not your network's administrator, notify the administrator that you received this information, which has been recorded in the file C:Windowsdebugdcdiag.txt.
The following also happened when DNS was queried for the service location (SRV) resource record used to locate an Active Directory Domain Controller (AD DC) for domain "zlnet.co.cc":
The error was: "DNS name does not exist." (error code 0x0000232B RCODE_NAME_ERROR).
The query was for the SRV record for _ldap._tcp.dc._msdcs.zlnet.co.cc.
Common causes of this error include the following:
The DNS SRV records required to locate a AD DC for the domain are not registered in DNS. These records are registered with a DNS server automatically when a AD DC is added to a domain.
They are updated by the AD DC at set intervals. This computer is configured to use DNS servers with the following IP addresses:
- 208.67.220.220 208.67.222.222.
One or more of the following zones do not include delegation to its child zone:
- zlnet.co.cc co.cc cc. (the root zone).
Any help would be greatly appreciated.
