Please have a look at the error message. It’s about EarthLink dial Connection.
Have you any idea about the
Dialing 4046541300
Error 680: There was no dial tone.
If you continue to receive error messages you can enable login for analysis.
Logging options can also be accessed by clicking the Remote Access Preferences menu item under the advanced menu of the Network Connection Folder.
I enabled logging option, but no result.
Please help me to solve the issue.
Thanks in advance.
Error Connecting to EarthLink dial Connection
Hello.
There might be a problem at the server side of your internet connection.
This may be due to server down.
Try logging in after some time.
If the problem still persists restart your computer and try logging in.
Check for connection settings.
Contact your service provider for further help.
Thank you.
Hi there user:
This error message occurred because there was no dial tone when your modem attempted to connect to EarthLink. No worries, you can easily resolve this problem. Just check your phone line. It should be plugged properly into your Windows dial modem. Then make sure the line isn’t busy while you attempt to connect.
Thank you for posting your query here at tecyv.com
Best regards,
