Hello everybody
Digikam is installed along with kipi plugin package on my system. I receive the following error during trying to batch convert jpg files to png
Cannot start 'convert' program from 'ImageMagick' package;
please check your installation.
Please help me to solve this problem.
Thanks a lot.
Error on conversion of jpg to png help
Since, jpg a png both are support able to windows photo viewer, Microsoft Office picture manager and paint. There is only manufacturer and some technical difference between them. Jpg (joint photographic expert group) developed by JPEG is considered as standard for professional photographers. Jpgs pictures are become light weighted when compressed. GIF (graphical interchange format) is referred to internet, which is not linked to photography. It is an older approach.
Anyhow for conversion you need converter software. Download and install it in your system.
URL: http://www.nchsoftware.com/imageconverter/index.html
You can also do it by accessing this software online. Follow the link below :
URL: http://www.pictureresize.org/online-images-converter.html
Click on ‘Choose file’ button. Select a jpg file from your system. Now convert to png( select by drop down) . click on blue button convert now. Follow the instruction and convert and download the converted file.
