Error converting .flv files to mp3 with QMC Software
I have Quick Media Converter HD Version 4.5.0.0 installed on my Windows 7 Home Edition x64 with SP1. The computer has Intel Pentium Dual Core CPU E5400 @ 2.70 GHz and 4GB RAM. I have used the QMC software to convert YouTube .flv files to mp3. But now I am unable to perform that because of the error. The details of the error is provided below:
FFmpeg version SVN-r22666, Copyright (c) 2000-2010 the FFmpeg developers
built on Mar 25 2010 06:05:35 with gcc 4.4.2
configuration: –enable-memalign-hack –cross-prefix=i686-mingw32- –cc=ccache-i686-mingw32-gcc –arch=i686 –target-os=mingw32 –enable-runtime-cpudetect –enable-avisynth –enable-gpl –enable-version3 –enable-bzlib –enable-libgsm –enable-libfaad –enable-pthreads –enable-libvorbis –enable-libtheora –enable-libspeex –enable-libmp3lame –enable-libopenjpeg –enable-libxvid –enable-libschroedinger –enable-libx264 –enable-libopencore_amrwb –enable-libopencore_amrnb
libavutil 50.12. 0 / 50.12. 0
libavcodec 52.60. 0 / 52.60. 0
libavformat 52.57. 1 / 52.57. 1
libavdevice 52. 2. 0 / 52. 2. 0
libswscale 0.10. 0 / 0.10. 0
C:UserskarenDownloadsVideo?Jason Derulo – Don't Wanna Go Home (Official Video)??.flv: no such file or directory
7 Service Pack 1,Home Edition,64 bits Execution
C:Program FilesQuickMediaConverter
C:Program FilesQuickMediaConverterQuickMediaConverter.exe
4.5.0.0 32 bits
FFmpeg version SVN-r22666 show available formats
C:UserskarenAppDataRoamingCocoon SoftwareQuickMediaConverter
And thedebug log file:
EIT_DATEHEUREÂ : 13/07/2011 14:07:02
– Pas d'identifiant dans le .err
13/07/2011 14:13:21:19 C:UserskarenAppDataRoamingCocoon SoftwareQuickMediaConverterbinStdFFmpeg.exe -i "D:NEW MUSIC VIDSYouTube – Gym Class Heroes- Stereo Hearts ft. Adam Levine (LYRIC VIDEO).flv" -vn -acodec libmp3lame -ab 192k -ar 44100 -ac 2 -y "C:UserskarenDesktopNew folder (2)YouTube – Gym Class Heroes- Stereo Hearts ft. Adam Levine (LYRIC VIDEO)_converted.mp3" status : 3
13/07/2011 14:13:23:72 Recensement Conversion Ok 20110713 0000131230
13/07/2011 14:13:26:43 C:UserskarenAppDataRoamingCocoon SoftwareQuickMediaConverterbinStdFFmpeg.exe -i "C:UserskarenDownloadsVideo?Jason Derulo – Don't Wanna Go Home (Official Video)??.flv" -vn -acodec libmp3lame -ab 192k -ar 44100 -ac 2 -y "C:UserskarenDesktopNew folder (2)?Jason Derulo – Don,t Wanna Go Home (Official Video)??_converted.mp3" status : 2
13/07/2011 14:13:28:52 Recensement Conversion Ok 20110713 0000013250
13/07/2011 14:32:31:67 C:Program FilesQuickMediaConverterbinStdFFmpeg.exe -i "C:UserskarenDownloadsVideo?Jason Derulo – Don,t Wanna Go Home (Official Video)??.flv" -vn -acodec libmp3lame -ab 192k -ar 44100 -ac 2 -y "C:UserskarenDesktopNew folder (2)?Jason Derulo – Don,t Wanna Go Home (Official Video)??_converted.mp3" status : 2
13/07/2011 14:32:34:27 Recensement Conversion Ok 20110713 0000012350
13/07/2011 14:33:01:25 C:Program FilesQuickMediaConverterbinStdFFmpeg.exe -i "C:UserskarenDownloadsVideo?Jason Derulo – Don,t Wanna Go Home (Official Video)??.flv" -vn -acodec libmp3lame -ab 192k -ar 44100 -ac 2 -y "C:UserskarenDesktopNew folder (2)?Jason Derulo – Don,t Wanna Go Home (Official Video)??_converted.mp3" status : 2
13/07/2011 14:33:04:04 Dump de l'erreur du module <WD140COM.DLL> <14.00Ej>.
– Appel WL :
Traitement de <pHttp.StatConv>, ligne <46>, thread <0>
Fonction <HTTPRequête>, n° de syntaxe <0>
– Niveau : erreur non fatale (EL_ONRETURN)
– Code erreur : 100073
– Code erreur WD55 : 0
– Pas de code d'erreur système
– Pas de message d'erreur système
– Que s'est-il passé ?
Mauvaise réponse du serveur HTTP (peut-être la réponse a-t'elle été trop lente –timeout?). Erreur 10060
– Infos de debug :
Fonction (10,61)
– Infos attachées :
EIT_PILEWLÂ :
Procédure globale StatConv (pHttp.StatConv), ligne 46
Procédure locale Mode_Video_Conv_Std (FenConversion.PROCEDURE.Mode_Video_Conv_Std), ligne 629
Clic sur BTN_CONV_PLAN1 (FenConversion.BTN_CONV_PLAN1), ligne 18
EIT_COMPOSANTÂ :
EIT_DATEHEUREÂ : 13/07/2011 14:33:04
