fchloe
Posted on - 12/16/2011
Guys can you help me with the error I am encountering while copying files using my Windows Vista Home Premium SP2 device. This is the message I am encountering, Error message : Error Copying File or Folder – Cannot Copy (music name/title) the directory or file cannot be created. Any idea how to fix this issue and resolve it? Thank you!
Error copying files in Windows Vista
Hello
You did deleting from this existing file in C drive which is now not recognized to install. You have to save this file on your system. Rather set up the file to hard disk which you copy original Windows 7 disk or service.
Another problem you may doubt that enough space to your disk need that could not copy. Cause it install lots of file to save. So check the drive where it saves.
Half of the application will not set the program. Scan at first if you have antivirus?
Take these one from above. You can solve your problem.
I think this is a purely copy write issue. If you are not able to copy these files then these files are copy write by the artist. You can either buy copyright form the user or you need to purchase another copy of the thing you want to use. But in case you are getting this problem with all of your files then you can add these files to a archive and then you can save them in disk. Also you need to make a full scan on your computer to make sure that you have no virus in your computer. To check the program that is causing this problem you can press ALT + CTRL + DEL from your keyboard and then go to process tab then you need to check the program that is causing this problem, you will then able delete this program form the list and to run your computer easily.
Boot your system in safe mode and follow the above steps if it is not possible in normal mode. You will be able to solve your problem.
fchloe
You're right Michal. I think the music files are write-protected. I will just download songs from iTunes or other free downloading sites. I also did some scan in my computer and found dozens of malwares. Thank you for reminding me to scan.
Thanks Michal Joran and also Cruise Berry!
TechyV always makes my life easier. :))
