Jeo Tolbert
Posted on - 10/31/2012
My Photoshop 7.0 has encountered a problem. I created an animation on Image ready. I found the problem on it. Another day when I tried to use the same, it threw an error message. My machine is running with Windows Vista. I uninstalled the Photoshop and reinstalled it but no result. Have you any idea? Please help.
Thanks in advance.
Error on Creating Animations on Adobe Photoshop Image Ready
Friend Windows Vista occur same error to lots of other PhotoShop 7.0 users. Try to run it on Windows XP if you want to run this same version otherwise if you prefer to run it on Windows Vista then upgrade it to C3 which is quite sufficient for Vistas or any new OS.
Hi Jeo Tolbert,
My suggestion is you should uninstall Photoshop 7.0, and install newer version such as Adobe Photoshop CS4 or CS5. In newer version, there is no Image Ready. But you can create animation much more easier by using animation in Photoshop directly.
You create many layers > go to menu Windows > Animation
Hope this helps
