An agent was created by using Lotus Connector Lotus Script Extensions in order to connect to a DB2 table. After the creation, I continuously received the error message below:
"Error creating product object" The line set src =New LCConnection ("db2").
I did not refer to the uidoc attached to the code. Please let me know what the problem might be.
Error Creating Product Object in Lotus Script Extensions
Dear Genelyn harvard
This error means that the interface db2 could not be loaded. It seems that the machine does not have a db2 client installed, or it's installed but the path statement is wrong so the db2 dlls could not be loaded.
The problem resolution is to re-install the db2 client and use it's functionality to connect to a db2 server, which is needed to catalog the db2 database or u will get an error when u try to connect to it. Note that u need a db2 client to be installed on every lotus notes client machine..
Hope this may help you.
Best of luck
