I was creating a scheduled scan with ClamAV's Immunet through the domain user's credentials. I'm not sure why it appears since it doesn't look like a domain credentials. Please tell me how to fix this. I need to schedule a scan since I'm not always at home. Thanks.
Error creating scheduled scan.
An unknown error has occurred.
OK
Error Creating Scheduled Scan in Immunet
First of all the Immunet 3.X is compatible up to Windows 7. If you are using Windows 8 or above, the compatibility is not guaranteed.
You may try the following to solve your problem
1.  If you are using any other antivirus then un-install them first.
2.  Install the latest version of immunet.
3.  Create a local administrator account and use the credential to schedule the scan.
