Error: Daceasy Accounting Software
Error message as “Retrieve Error 46: Operation to read-only file denied and sometimes Error like some key files missing”, I am getting continuously. I tried to reinstall that in another drive but failed. I also tried to use command prompt, typing the command in the data directory “attrib-r-s-h”, but the problem continues.
Even unchecking the read only, it was tried to open in safe mode. I love to give thanks in advance to anyone providing solution resolving this problem at the earliest.
Error : Daceasy Accounting Software
Hallo Alysa,
The error that you are getting when using the Daceasy Accounting Software usually occurs when you attempt using sequential READ operation has on a file that is open in the INPUT or I-O mode but then there is no valid next record has been established just yet. It is a problem associated with how you are using the commands. To resolve therefore, you will need to do the following:
Revisit the commands that you are using and make sure that you are declaring them properly. Also ensure that try disabling read only.
You also need to make sure that you did not delete any files related to Daceasy Accounting Software by mistake for such an error can result when some files are missing from your computer.
Carl
