Mayrett
Posted on - 08/22/2011
i am using visual studio 210 ultimate edition, i am having trouble while connecting my program to database,
the connection string is
string connection = @"Provider=Microsoft.ACE.OLEDB.4.0; data source = AuCeph.accdb";
when i run the proram i got this error,
Can anyone guide me to resolve this error,
Error in Database connection in C++ program
Hello mayrett, the best solution for you is that you can install again this program and then work again because this error shows that there are some files which are now corrupted and will not able to work and also create a hindrance for you to operate some functions for the visual studio.
Here is the error it shows that there is an invalid program or also unregistered so this error are only comes when some of the files are not working at that pace which is required from those files.
So the best way for you is that start update your software and also scans timely all files of the computer including all software and its backup. I hope it will solve your problem.
