Olivia Aust
10 points
Posted on - 10/12/2012
ERROR DATATYPE MISMATCH 1629 The data supplied is the wrong type.
How many have experienced this?
I use to have a webI R1 report which had user response.
Although I did not use the quotes in the function my code was working fine.
But after I transferred to R2 the same code shows me an error datatype mismatch once I put the numbers in quotes everything was fine.
Why is this so?
Hello Olivia,
That is an issue that is probably due to the windows installer package that you are using. In order to resolve it, you will need to uninstall windows installer by going to Start, and then Run.
After that type msiexec /uninstall and then confirm that you want to uninstall.
After that you will need to install the windows installer package that is compatible to your OS.
Nicke
