Error Dependency is not satisfiable
I installed Gnome desktop and a lot of games came with it and uninstalled the games to get back the chess game. I get this weird error message when I try to download the deb file and install it in Gdebi. It all happened under the Linux Operating System. Should I need to make changes in repositories? Please help me with a proper solution so that I may continue my work. Thanks to assist me.
Package Installer – Google –chrome-stable
Package: Google –chrome-stable
Status: Error: Dependency is not satisfiable: llbudev0 (>=147)
Version: Chrome Linux Team ‹[email protected]
Priority: optional
Section          : web
Best Answer by
Answered By 0 points N/A #175035
It seems like you are using Ubuntu. Whenever you choose to install the Chrome, there is an embedded Flash plug-in. Some dependency errors are surely expected. Always try installing any software or update only from Ubuntu software center.
For Flash you can run the command: "sudo apt-get install flashplugin-nonfree". In your case run any one of the bellow commands for different chess games:
 sudo apt-get install xboard
 sudo aptitude install brutalchess
In fact Chrome has already fixed the dependency issues.
