Sheri Kay
10 points
Posted on - 02/23/2013
I am trying to run the setup file for installing plugins I got this error:
"Can't install all files
Please check your destination directory for free space"
I am getting the same error even if I use the downloaded setup file or the zip version.
I have more than 71 GB free space on my hard disk.
I am getting the same error even if I download and install.
Please advice
Can’t install all files!
Please check your destination directory for free space!
Error destination directory for free space
You mentioned that you have 71 GB of free space on your Hard-Disk. However, you have not mentioned the amount of free space in the particualr partition on which you are installing your software. You can check your partition allocation by following these steps:
Right click on the specific drive letter
Click on Properties.
There you can see how much space you have left in the partition where the software is failing to install.
To solve this problem, you can delete unnecessary files from that partition or install the software in a different partition where there is enough space.
If the problem is not for what I proposed the solution, your system may have been infected by viruses. You should scan the whole system for errors and malware.
Regards
