Error with Digi002 Rack in Mac Pro
Running PT9 LE with the toolkit of full production, on an Intel Mac Pro (4-core, 16gb of ram), which has four years with a Digi002 Rack. I am running the system from a disk SSD OWC, and all samples and audio files are in other SATA disk drives.
These are the two errors that appear all the time, especially the upper error (-6093).
Pro Tools also occasionally lose contact with Digi002, and i have to reboot and reload the meeting. I've tried running a Pro I/O tools of aggregate and the buffering errors are even worse.
When i have a lot of intensive virtual instruments and plugins running, PT is slow when you stop and start the playback and that is to be expected, but if i can upload a virtual instrument (such as vacuum or Xpand2) at a meeting of empty, i am going to start to get the errors. I've tried all the remedies that i have never read and i'm simply sick and tired of this. Constantly makes me angry when I'm trying to work. Sometimes even i go to these errors when I am working on projects post-sound, without the use of any virtual instrument.
So my question is, what is more likely that is going to fix this problem if you throw money away on the?
A new system native PT HD will correct the problem?
A new 12 core Mac Pro will fix the problem?
Does a new MBox Pro will fix the problem?
Thanks for reading.
