dj_dreamz
Posted on - 07/22/2011
hi I was installing the game gta vice city it is on two cd set when it ask about to insert another cd I do but It wont run intsead I get message the cd is not inserted please help its my favorite one i got xp Pro with service pack 2
ERROR_DISK_CHANGE
107 (0x6B)
Error disk change gta error 107
Please copy the two cd's in your system and then you install the file, because of some hardware issues it will say like that.
http://www.processlibrary.com/en/
Check this site for fixing that error.
Thanks,
Janine08
5 points
Hi Dj_dreamz, I think I know what your problem is.. ERROR_DISK_CHANGE 107 (0x6B) means: The program stopped because an alternate diskette was not inserted.Â
Now that you know what does ERROR_DISK_CHANGE 107 (0x6B) mean, you may avoid this kind of system errors in the future. However, The Windows System error codes list thousands of codes due to various kinds of problems, like ERROR_DISK_CHANGE 107 (0x6B), you can't remember them all. So how to solve the Windows error codes forever, like ERROR_DISK_CHANGE 107 (0x6B)? We recommend you to use Advanced SystemCare Free to protect you from being disturbed by ERROR_DISK_CHANGE 107 (0x6B) Windows error again.Â
ERROR_DISK_CHANGE 107 (0x6B) may bring you unrelated window dialogs. The automatically window dialogs affected computer’s performance, causing computer slow down, "play dead" in period, blue screen and system trash.Â
To avoid ERROR_DISK_CHANGE 107 (0x6B) window dialogs, and keep your computer in secure. it is highly recommended to take a free scan and fix ERROR_DISK_CHANGE 107 (0x6B) Windows errors in time.Â
I hope this will help.. Good Luck 🙂
