alvaldez
10 points
Posted on - 04/04/2012
Good day!
I would like to ask some experts to help me on this.
Could someone might tell me what causes this error message?
Error:
The Visual Basic for Applications project in the database is corrupt.
Error Display when Opening MS Access file
 Hi Alvaldez,
Your error message would be because of version difference , now to remove this error message you can have mentioned below ways.
1. Now, to make new versions backward compatible Microsoft providing free compatible version at this link.
  You can now view files saved in Office 2007 and 2010 using MS Office 2003.
 2. You can save/convert your *.pptx,*.docx or *.xlsx file into *.ppt , *.doc ,*.xls respectively by clicking onto file -> "save as" option.
 3. Apart from that you can download and view your presentation in different softwares.
 Using online Convertors
                 Zamzar is the one of the free online convertors, which will allow you to convert .docx, .xlsx and .pptx to a different format compatible with .doc , .xls and .ppt respectively.
 Further you can use some different compatible software also. Below are the few suggestion.
  These are the open source software which can be downloaded for free
 OpenOffice
 StarOffice
 You can view your presentation online through below Google application
 Google Docs
 For MAC Os you can have mentioned below softwares
 Microsoft Office
 AppleWorks
 OpenOSX
 In linux machine you can download below tar ball or rpm files.
 OpenOffice
 KOffice
 GNOME Office
 Hope this solution will help you.
Thanks,
Sophia Taj
