I am using Windows 7 x64 with GameBooster 1.3 installed on it. I received this problem as I press on
Display All Latest Procedures. What should I do?
Game Booster
Could not convert variant of type (Null) into type (Olestr)
Error on Displaying All Latest Procedures in GameBooster
Has the game booster been working properly the other times that you have used it or has it been displaying the error all the time that you use it? In case the error just started occurring, then I suspect a bug may have developed in the application that will require that you fix it. The bug may have been caused by an infection by a virus or some changes that you might have made to the computer, and therefore I will suggest that you do the following to try and fix the problem:
Check if there are any scripting problems in the application and fix them.
You will need to run system restore to remove and changes that might have made that are causing the problem.
In case the error is due to a bug, you will need to run registry fix program to fix those errors.
-Keegan Robb
