Hi!
I use Asus notebook. My PC Configuration are i3 processor 2nd gen, 2GB RAM, 500GB HDD,1GB graphic card and my Operating System is Win7 32.
When I installed Maya 2011 version, I was getting an error message that displays: Install Microsoft Visual C++ 2005 Redistributable (x86).
Then, I installed C++2005. But the same error appeared again while other software (max 2010) runs easily.
Please help. Thanks.
Error displays: Install Microsoft Visual C++ 2005 Redistributable (x86).
I think you did not read first the system requirements of Microsoft Visual C++ 2005 Redistributable Package (x86) before downloading and installing it on your machine. Your operating system is not compatible with this version of Visual C++ runtime components. This version of Microsoft Visual C++ is only compatible with these Windows versions:
Windows 98
Windows 98 Second Edition
Windows Millennium
Windows Server 2003
Windows 2000 Service Pack 3
Windows XP Service Pack 2
You are using Windows 7 32-bit. What you need is the right version of Microsoft Visual C++ that is compatible with your operating system. I found a version that I think is compatible with your Windows version. Download and install Microsoft Visual C++ 2010 Redistributable Package (x86) at http://www.microsoft.com/en-us/download/details.aspx?id=5555. This version is compatible with Windows 7. Before installing Microsoft Visual C++ 2010 Redistributable Package, uninstall first Microsoft Visual C++ 2005 Redistributable Package to have a clean installation and avoid overlapping of the components.
