jamie diaz
20 points
Posted on - 11/06/2011
This is the first time I visited this forum and I am hoping that I could get some help regarding the errors I encountered in the DNS event viewer, which are way too much. These errors would result for clients to be unable to ping the server and the server unable to ping the client systems. The sharing resources are not functioning as well. How will I correct it?
Error in DNS Event Viewer
Hello Jamie,
Gnerally, you are getting that error because your DNS or ISP does not support any registration records of DNS and DC's. On all members of AD Domain, only use your internal DNS. You need to configure your DNS for internet access. Please follow the steps below to configures your DNS:
Configure your IP/TCP
Click start > settings > control panel
Double click your dial up connection
Right click LAC (local area connection)
Click properties Internet protocol and click properties again
Go to advanced and click theDNS tab
Click DNS suffixes
Click the DNS check box
Click ok
You can visit this link to know more about DN troubleshoot.
-Zorian
