I downloaded an application named Open Home Version 2.6 and when I am about to unsealed it an error is stating: Unable to determine open home misconception:android.app. Wallpaper Service$stub or thing like that. Can somebody tell me how to fix it?
Error on downloading Open Home in Android
That could be because the software that you downloaded needs you to have some keys of some sort for you to be able to use it. Therefore if the application has a readme document with it or a guideline on how to install and use it, then I will suggest that you read it and follow the steps for installing and using that application. Maybe the keys required to use that software are available on the manufacturer’s site and therefore you will need to access it and see the reviews that have been written for that software. In case you do not find help on the manufacturer’s site you can just contact the customer support and explain to them your case.
-Thompson Locker
