Hello fellows,
An error with drivers of ion webcam windows 7. The webcam cannot be launched for some reasons regarding drivers. Maybe the drivers are not installed properly or not compatible with my windows 7 operating system. I have to traced all the possible problem. I hope you can help me resolve this issue.
Lindsay Wendy.
Hi Lindsay Wendy,
If you want to know if your webcam have a problem then you must check your device manager by right clicking My Computer > Device manager. If you see this
 then you really have a driver problem. All you have to do is right click USB camera then choose Update Driver Software.
Please follow these steps to check the driver for your camera device.Â
Wright click on my computer and click device manager
Check for camera drivers here if they are not installed properly then you need to install them
To install drivers you need to first download drivers for your device or use the DVD/CD that comes with your device
Install the driver and software and you will be able to use your camera
Smith Thompson
