Isabellartd
70 points
Posted on - 05/25/2012
Here is a problem I am facing at the time of installing the game Call of Duty as at the time of Installation I got the validation error hence kindly provide me why the problem arising and the solution to this problem.
Thank you.
Error during initialization:
Failed to validate
F:Call.Of.Duty.MegaPack-KaOsCall.Of.Duty.Black.Ops.RERIP-KaOskas-codbomainlocalized_
english_iwoo.iwd
Error during initialization : failed to validate when installing Call of Duty
Hello Isabellartd,
Maybe there is an incompatibility with the application or a part of the application wherein it failed to validate. The error must related to location, language or a missing file. Try to go to "Stream Client" and select "Game Library". Right-click on "Black Ops single player or multi player" and choose "Properties". Under the "Local Files Tab", click "Verify Integrity of Game Cache".
It check to see if all the needed files are available to run your game.
You may see that the "verification is complete" and it will automatically download the proper files. If those procedure fails, try to defragment with the cache and the game files.
Hope this information would be useful.
