Error during installation ubuntu 2.5
Ubuntu error.jpg [/attachment] hi guys, I have downloaded Ubuntu 2.5 and I want to install it from windows 7
Actually George this error shows a message of the retrieving file it means that there is a serious problem with any of your files of Ubuntu and that create a hindrance in opening of your this file. So the solution for you is that do install a new file of this software with a key registration and download it now from a well known and a reliable source because some of the time many sited are full of viruses so whenever you download it then that virus also comes into your computer. So also scan all files for viruses as well and then try to run this program it will surely work.
Cheers.
Yes.
That is a major problem that is faced by most of the Wubi users.Â
This explanation assumes that you have downloaded Ubuntu and Wubi first and then you want to install Ubuntu using Wubi:
Problem:
The error says that it couldn't retrieve the required installation files. That means it was not able to access the main Ubuntu ISO file that you downloaded or by any means, was on your computer.
Solution:
The only best and perfect solution for this is to place the main Ubuntu ISO file in the drive or folder in which you want to install Ubuntu. So, ultimately the Ubuntu ISO file and the Wubi application will be in the same drive (or) folder. So, now Wubi will be able to access the main Ubuntu ISO file and you will not have any problems.
I would suggest to partition the main drive and start another one [D:] and then put all the Ubuntu installation files including Wubi in that drive and then start installing.
Example:
Regards,Â
Phani.
