I recently downloaded MediaCoder 2011 Build 5002. And when trying to encode the audio part alone, I received an error message. I have a video file that contains two audio tracks and encode the audio only. The settings are:
MKV File
Encode: Nero Encoder
Format: HE-AAC V2
Source: Mplayer
Resample: Original
48Kbps with normalization
Hint track Enable
Dual Audio Track Select
I have tried following the same process in MediaCoder 0.7.3 Build 4600 and was able to complete it without any error. What is causing the error in build 5002? How can I resolve it?
Error Encoding Audio in MediaCoder 2011 Build 5002
What is the error message that you got? I wish you could have posted it. But some of the reasons I suspect might be a cause to that problem are the following:
The media encoder does not have support for the MKV files, and therefore you should search for the right version of the media encoder that will enable to encode the MKV files.
There could be compatibility issues too. And that will happen if the media encoder that you installed is not supported by the operating system that you are using. In that case you will need to check the system specifications and then download the right version of the media encoder that can work on your operating system.
-Keegan Robb
