Pat M
Posted on - 10/16/2011
I was trying to play this game when this error message popped up (see below).Â
It said that the PhysXLoader.dll file was missing.Â
I was able to find a website where I could download the said file, but the game still acted the same, same error message.Â
I have found another website saying that I needed another video driver. I really don’t know how to fix this now.Â
Please help me.Â
Game.exe – Unable to Locate Component
This application has failed to start because PhysXLoader.dll was not found. Re-installing the application may fix this problem.
Error encountered PhysXLoader.dll file missing
The game could be corrupted or a virus have remove this certain file in your game that deleted it.
Solution 1:
Installing an anti virus and then scanning the whole system is a key in this solution. So this is what you have to do first. And also install anti viruses which gives you a good protection and that is a genuine software.
Solution 2:
Reinstall the program again, but I suggest remove it first by uninstalling it in program menu in the Start button or use the Control Panel and then Add and Remove Programs. Then install it again but if you have any save files don't forget to back it up or just don't do any complete uninstall.
