Fred Legada
Posted on - 11/29/2011
I was using ImgBurn in burning my files and backing them up to DVDs.
 However, randomly I got this error message, see screenshot below. Â
ImgBurn
ConnectFilters (Source, Sample Grabber) Failed!
File Name: E:ROMsSaturnfatal fury 3Track02.ogg
Reason: No combination of intermediate filters could be found to make the connection.
Hint: You may need to install some additional DirectShow filters in order to support files of this type or the file might be corrupt.
I would really like to follow what was recommended but I wasn’t sure on which DirectShow filters to download. Â
Can you please help? Â Thanks.
lee hung
75 points
Error encountered when copying files to DVD using ImgBurn
Hello Fred Legada,
I will suggest that you search for DirectShow files for the ImgBurn application, download them and install them, and then try writing the files again and see if the problem will be solved.
In case that does not work for you, I will suggest that you try other media burners like Nero express and ashampoo burning studio, which have a lot of features, and I think they have the DirectShow tools already embedded in them and therefore you will not need to go downloading them again so that you use the applications.
Hope this helps.
__
Regards
Lee Hung
Hello Fred,
It seems your program did not install completely or some program files have been corrupted. To solve the problem, try to remove the whole program from your computer system and try installing again by acquiring another package i recommend the latest package and ensure that all the files have been copied to your system successfully.
Another option will be to acquire another type of image burning software such as Ashampoo burning studio or Nero Express. These two programs are among the best image burning software and once installed, there will be no problem when trying to copy image files.
Thank you.
