anonymous
7060 points
Posted on - 06/17/2012
My OpenInstaller keeps on crashing, can someone help me?
I had a plugin made, and I was working on making an installer when it suddenly closes. I get this error report after:
Openlnstaller has encountered a problem and needs to close. We are sorry for the inconvenience.
Kindly can someone help me
Thanks
Open Installer
Open Installer has been encountered a problem and needs to close. We are sorry for the inconvenience
If you were in the middle of something, the information you were working on might be lost.
Please tell Microsoft about this problem
We have created an error report that you can send to us. We will treat this report as confidential and anonymous.
What data does this report contains?
Why should I report to microsoft
Send the Error Report
Don't Send
Error Encountered While Installing OpenInstaller
If this is the first time it happened with your application, try restarting your computer then try it again. A fresher system might fix the problem. If it still doesn’t work, check the system specifications of the program you are using. Since your computer is running on Windows XP, visit again the site where you downloaded OpenInstaller and then verify if the version you downloaded is compatible with your operating system. If it doesn’t, then just find a different version that works with Windows XP.
If you verify that the application supports your current operating system, try doing a clean installation of OpenInstaller to restore it to its default configuration and possibly fix any corrupted files that may have developed during your previous installation with it. Uninstall OpenInstaller then check your computer for any possible errors. Use a disk utility application to check the system. Install the application again after this then check if this fixes the problem.
