MariaF
Posted on - 10/19/2011
I was new Autodesk Revit user when this error message popped up, see below. I was trying to start the said software when the error happened. I tried reinstalling the software the same error message was encountered. Any advice how to fix this problem. Thanks for the help!
Revit.exe – System Error
The program can’t start because QtGui4.dll is missing from your computer. Try reinstalling the program to fix this problem.
Error encountered while starting Autodesk Revit
The error said that QtGiu4.dll is missing, that means that the installer that you used in not completed nor may some other dll file is missing in the installer. You can try to download the QtGiu4.dll or you can search Google where to download QtGiu4.dll then install it to your computer, or in some other place it is a process where it can be modified and used to attack your computer and bring your computer to problem or damage and will bring your security at risk. Try to scan your computer by available free anti malware program in the internet to checked out and to resolved your problem.
