hotfarooq
Posted on - 01/19/2012
I am having issues with my HP Software Framework on my Windows Vista 32-Bit laptop.
I posted a screenshot of the error in my Event Viewer 4 and 5.
I tried to uninstall HP Software Framework and even reformatted my computer system, but this error remains.
How can I fix this?
Event 4, CaslWmi
Warning |[CaslWmi]A::A{hpCasl.enReturnCode(object&)}|Error e_BIOS_INVALID_COMMAND_TYPE from BIOS WMI call Command/30h while getting EDID Data
Event 5, CaslWmi
Error |[CaslWmi]CommandFolio::A{hpCasl.enReturnCode(int&
)}|Error 0xe_BIOS_INVALID_COMMAND_TYPE from BIOS WMI call Read/2Eh while getting Folio state
Error in Event Viewer with HP Software Framework
You will need to run "System diagnostic" and see if you can find any problems as follows:
First you will need to turn on or restart the computer.
During the booting process, when you see the “Press the ESC key for Startup Menu” message displayed in the lower-left corner of the screen, you will need to press esc on your keyboard.
And when the Startup Menu is displayed, you will need to press f2 on your keyboard.
You after that need to click the diagnostic test you want to run, and then you will follow the on-screen instructions.
Once you are done with the diagnostics test and you need to stop it, you will need to press esc on your keyboard.
Experttechyv
