Error executing the query in Visual Web Developer 2008
I am a web developer and started my work including a new web site with VS 2005 and added a sqldatasource and connect with the AdventureWorks sample database. I checked the connection working fine and save as “AdventureWorksConnectionString”. At the end I received an error message while testing query with 'test query' button . How can I remove this error? If you have any idea please share some ideas. Thanks.
Visual Web Developer 2008 Express Edition
There was an error executing the query. Please check the syntax of the command and if present, the types and values of the parameters and ensure they are correct.
Invalid object name ‘Product’.
