When I use Facebook chat for windows 7 phone and I try to sign in I get the following message, "problem getting Facebook login page. please make sure you have access to facebook.com in this network" , it used to work fine and it crashed one day and now I just get that message. Any advice?
Error with Facebook chat for windows 7 phone
Hello Dominic
From what I know, this is an issue with the application developed for Windows 7 phones. What you should try, is this. Check for an update of the application. Or you could just uninstall it, and then install it again.
Also, login to Facebook from your computer. Go to Account Settings, Security, and there, Disable Login notifications. This should make your application work.
I hope you found this information useful.
Randolph
