Error ‘fan 90b’ Occurred While Working On My Laptop
Yesterday I was installing an electronics software on my hp laptop, and just after installation when I was about to start the working I found this displayed.
The above problem had been encountered in laptops that are old enough with time, and those have been used a lot as per their functioning lifetime and limits.
It is a hardware issue of a cooling fan, the system fan is not spinning at the required speed, or a problem exists related to the heat removal system.
To remove this error, various following things can be done-
The problem there is the system fan or the cooling fan assigned to the processor. In a standard CPU tower, there are different cooling fans installed. There is a cooling fan for the CPU or the processor, for the tower enclosure, and the video card. The problem that was detected in that error was with the CPU cooling fan.
One possible reason is if the cooling fan stops working or it operates at a much lower speed. When this happens, continue using the computer is not recommended because it can damage the processor itself. You might end up frying the processor. In this case, you need to replace the cooling fan with a new one.
This problem can also happen when the cooling fan operates at a much faster rate than normal. This happens when you install a modified cooling fan which operates at the fastest speed. The motherboard detects this and will trigger an error when the cycle rate is above the scale.
