Error with FM Genie scout 2012
Hello I am trying to work with the FM scout 2012 but the problem I am being faced is that I am getting the error in loading Entity number as showing it to 0 and position of the file is being displayed as -1 and even database version is 1686, and I am sure with the latest version of FM Genie Scout in which the file is not corrupt.
Dump files are even kept in the same folder FM Genie Scout.
Any solution will be greatly accepted.
Thank You.
Error:
Connecting through WAN Miniport (PPPOE)…
Error 651: The modem (or other connecting device) has reported an error.
If you continue to receive error messages, you can enable logging for analysis.
Enable logging for logging option.see diagnostics
Logging option can also be accessed by clicking the Remote Access Preferences menu item under the Advanced menu of the Network.
Connection Folder
