Error found not installed on current user (help)
Hello.
Want to solve this error:
Microsoft Office Word
MS Office Word has not been installed for the current user. Please run setup to install the application.
Help needed.
Hello.
Help needed.
This problem usually occurs if a non-administrative user on the computer has no specific permission to modify a certain file/s being used by the Microsoft Office Set-up.
To resolve this problem, log on to the computer by using an Administrator user account then start Microsoft Windows Explorer. On the Tools menu, click Folder Options then click the View tab. Under Hidden files and folders, click Show hidden files and folders.Â
Click to clear the Hide extensions for known file types check box, and then click OK. Open the following folder: C:Documents and SettingsAll UsersApplication DataMicrosoftOfficeData.
If you are running Office 2003, right-click Opa11.dat or Opa12.dat if you are using Office 2007, and then click Properties.
If you are running Office XP, right-click Data.dat, and then click Properties. Click the Security tab then click Advanced. Click the Permissions tab. Click to select Everyone in the Permission entry list, and then click Edit. Click to select the Full Control check box then click OK three times.
If these steps do not resolve this issue, delete the Opa11.dat,Opa12.dat file or the Data.dat file from the following folder, and then restart an Office 2003 program or an Office XP program.
First I have a few Questions.
