Error! Function set incorrect in HD44780 LCD Module
Hi there,
I try to use HD44780 LCD Module to build a module. However when the simulate is trying to run, an error message appears and it says that the function set is incorrect. Please find below the screenshot of the error message for your reference.
Can any expert explain this error and any suggestion to solve the error? Thanks in advance.
Error! Function set incorrect. DL=1 N=0 F=0
Function set must be DL=0 N=1 F=0
