freakleash
Posted on - 01/29/2012
I had a problem with SoftwarePassport Armadillo Professional Public V6.60. I could not make a license key as it always show a failure in generating my key. I installed this software on my Windows Vista PC. Is there something wrong with the configuration? Does anyone here who has the same error as mine?
Key Generation Failure
There were issues generating your key:
OK
Error in Generating Key with SoftwarePassport Armadillo Pro
Hi
The picture is showing that there is something wrong in your software either there is some file which has missed during installation or you need to re-install this software. I think you have to re-install this software and then again generate the key. Hope this will work. Or the other option is you need to change the version of the software and then reinstall the software again and then it will solve. If this will not solve then you need to check whether you are installing 32-bit or 64-bit. If you are installing 32-bit then need to install 64-bit and if you are installing 64-bit then you need to install 32-bit. Hope this solution will solve doing this.
points
Hello…
Its too old but… Windows XP and Windows 10 not worked for me…Use Windows 7 32/64 bit its worked fine for me.
Hope this help.
