Error on GIMP GNU Image Manipulation Program
When I open GIMP GNU Image Manipulation Program I get an error as shown below. I wanted to edit some images in form of jpg, png and gif.
Value for PNG text chunk Description cannot be converted to ISO-8859-1 encoding.
GIMP Message
Answered By 0 points N/A #176092
The error is caused due to bug in OpenEmbedded meta layer. Due to some reason ISO8859-1 needs libc.so in addition to libc.so.6.
To get around this problem you need to create a softlink to libc.so using the command ln -s
For example: ln -s libc.so.6 libc.so
Restart the application and you will see the error is gone.
