halin dan
80 points
Posted on - 02/08/2013
HI Experts,
I did try to load an xyz file with “Global Mapper 9.03”. When the file loaded completely, it attempted to triangulate and provided the above error message which you can see
What is going on? I am not able to use the program to finish something.
Unable to grid 3D points from desoto1-8603, xyz
GenericASCIIOverlay.cpp -2390
Build Time: Apr 30 2008 10:25:22
Error, global mapper won’t load xyz ASCII
You probably have been receiving other errors before that. This is common. It happens because the program was not installed properly. If this is the case, you can fix this problem by downloading the latest Global Mapper file at http://www.bluemarblegeo.com/products/global-mapper-download.php. Overwrite your existing V9 installation with the contents of the downloaded file and this will solve your problem.
